First, Specs:
Abit NF7
AMD XP-M 2500+
ATI 9800pro
NEC 2550 DVD burner
SB audigy 2
Western Digital JB 120gb hard drive and/or WD JB160GB
Aspire PSU (bad psu, I know. I just don't have the money for a new one)
*Trying to install* Windows XP Pro
Second, My problem:
When I try to install Windows XP it says that I have no hard drive present (after I select the "install windows XP" option).
Third, What i DO know:
a) My computer recognizes the hard drive at boot AND in the bios
b) My hard drive is spinning up (can feel it).
c) This hard drive works (was in another computer, reformated and pulled)
d) I have the correct boot sequence.
e) This computer was working until about a week ago when I got a "HAL" error. I re-formatted thinking that would fix it. It did get rid of the HAL error, but now the windows install doesn't recognized either the 160gb or 120gb hard drive.
Fourth, What I have tried:
i) Different IDE Cable
ii) Different IDE slot (My dvd drive still works when plugged into the other ide slot, so I don't think it is that.)
iii) Every freaking jumper setting possible (including no jumper)
iv) A different working hard drive (still no luck)
Fifth, Is there something I can download off of WD's website that will help?
HELP AT! I have no idea what is happening. What else can I try?
Thanks as always for help, and let me know if you need any more info about my computer or what I have tried.
Abit NF7
AMD XP-M 2500+
ATI 9800pro
NEC 2550 DVD burner
SB audigy 2
Second, My problem:
