I can't get the A7V BIOS to recognize any IDE CD-ROMs. I need to reinstall Win98 so I need to either boot from a CD or a DOS floppy, but I can't do either. The CD drives work fine when I boot into Win98, but when I start with a floppy with the proper drivers it says there are no drives present. I also created a Win98 boot disk (the one that gives the option to boot with or without CD support), but to no avail.
I've tried every possible combination of different cables, and changing the master/slave/cable select jumper. I even tried the CD drive in place of the HDD--which works fine on primary/master--but that didn't work.
I would settle for booting from a CD drive but the ATAPI CD-ROM option in the BIOS lists only "None" and "Disabled."
Also set the primary/secondary master/slave options to Auto, CD-ROM, etc. to force the issue but no luck.
Thanks for any help
Thanks for any help
