Okay so I installed a new vid card and then I attached 2 Rosewill 120mm case fans as intakes onto my side panel. I hooked one up to my motherboards sysfan3 connector, and the other fan using an adapter to my PSU.
The fan hooked up to sysfan3 started up no problem on initial boot-up but the second fan that was running off the PSU didn't spin at all. I thought okay I must have done something wrong when I decided to power it off my PSU. My system began loading windows and it began to hang, so I took my side panel off and now the CPU fan had stopped spinning! It would hitch like it was about to start spinning but then would stop for a few seconds..then hitch again.
I immediately unplugged the rosewill fan that was getting power off sysfan3 and sure enough the cpu fan spun right up and behaved normal.
My motherboard is the MSI Z87-G41 http://us.msi.com/product/mb/Z87-G41-PC-Mate.html#/?div=BIOS
And these are the fans I'm working with:
http://www.newegg.com/Product/Produc...82E16835200049
The other two sysfan connections on the mobo are already being used by the front intake and rear exhaust fans that came with my corsair 300r
What is the best way to power these new rosewill side panel fans?
Can someone tell me what the heck I'm doing wrong?
Thanks!
Thanks!
