Not sure what happened. I lost the ability to open a new window when I hold shift and click on a link in IE6. It comes up on the taskbar, but I have to right click and hit maximize to open the window. Any ideas appreciated. Thx.
It sounds like the window is getting opened, however it is located outside of the visible area of the screen, therefore maximizing it allows you to view it.
I dont think a reinstall of IE will fix the issue! you just need to find the prefs for IE and trash them.
Here is what I would try, delete the registry key located at: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Document Windows
Than logoff/login and relaunch IE, that should resolve the issue
If that doesnt fix it just delete the whole IE key: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer
Good Luck!
-Spy
edit: Why dont I think that a reinstall will resolve the issue?
Because reinstalling will use the prefs that were created before and will not remove them.
