Problem on Asus P5N-D
FalseChristian
3,322
I like this nVidia 750i mobo but I'm stuck using Microsoft's lousy PATA IDE drivers from 2001 and my hard-drive is stuck in UDMA mode 2. Is there anything I can do to update these drivers?
Thnak you.:confused:
JustaGeek
2,827
Make sure that you use the 80-wire IDE cable.
If you use the 40-wire cable, often supplied with the CD/DVD drives, you will be stuck with the lower transfer speeds.
Good luck!
VirtualLarry
56,571
10,207
There's absolutely nothing wrong with the MS ide drivers. In fact they are far more compatible than 3rd-party drivers when it comes to things like CD-burning.
