Solved, see video: http://www.youtube.com/watch?v=gA0OwCskOQc
I have a problem:
I have a Core i7 920 CPU with Intel DX58SO Motherboard and GTX 280 on Vista 64.
When I power on my computer after it been turned off during the night it will start up, work ok in Windows but then it will freeze when I load an intensive 3D video game like Modern Warfare 2 or Battlefield 2.
Here is a video showing the problem
But it will work fine when I power it off and then power on, then it will work fine like there is no problem at all.
The problem only happens on cold boot of the system, for me it happens when I come back home after work and I turn on the computer and it will freeze on a 3D game, restart doesn't help it will happen again, only way to stop it from happening is to power off and then immediately on, then it will work fine again.
I think it's a motherboard issue because I read this post so I contacted Intel support and they told me to format my computer and perform a clean OS installation, I did it and the problem still happens
Now Intel support says I have to check with a different video card because they think it is more likely to be a graphics card problem and not mainboard.
Anyone here might might know if this is more likely caused by mainboard or video card?
Thank you.
I have a problem:
Thank you.
