Hi.
I have a DFI Lanparty UT nf4 SLI-DR with an AMD Athlon 4400+ dual-core.
Memory:
2x OCZ PC-3200 400Mhz (slot 1 & 3) OCZ4001024ELDCPER2-K 2-3-2-5
2x OCZ PC-3200 400Mhz (slot 2 & 4) OCZ4002048ELDPE-K 2.5-3-2-5
Lasted bios (2006-06-04)
The bios only detect 2gb. Same thing for Windows
But CPU-Z in windows show all the 4 dimms.
Why is the bios not detected 3gb ?
I know the maximum ram is 4gb so 3gb should be correct ? I don't care for the moment about the speed or if it dual channel or not, I only want to see 3gb and I can't even do that.
Does anybody knows why ? And also, if the motherboard doesn't handle this kind configuration, where is it written ? Because if DFI doesn't say it, it SHOULD be supported.
Memory:
