problem installing winME
doneedlove
1,135
hi,
I got this problem while upgrading to winME. I used win98SE then i pop in the upgrade cd.. it went smoothly until it hit the 10 min left "installing plug and play devices" .. i got to this part and then the computer hang on me for a long time then the instruction said reboot if it doesn't responds for a long time. So then i reboot them. It got this same problem again so i formated and then installed the winME from fresh. The problem still occurs at the 10 min mark. So i said forget about winME.. it's suck.. hahaha.. maybe my system got SCSI hard drive that's why it doesn't support or it got conflict with my plug and play devices.. any idea?? please help.. thanks..
DoNeedLove :)
AMB
2,587
A Via Chippest Motherboard:
- Via 133 A
- Via KT133
- Via KX133
Not A Via Chippest Motherboard:
- Intel Bx
- Intel 820
- Intel 815
doneedlove
1,135
hi,
Hum.. i don't know what is the chip set mother board i got.. but seems like it doesn't work with WINME so i goes back to win98SE.. ahhah. any other idea?? thanks..bye.
DONEEDLOVE :)
doneedlove
1,135
hi,
I borrowed from my friend, and also used the one i downloaded from someone's server..
DOnEedLove :)
Edski
911
Does your system hang on boot now? If so, you may as well start from scratch, I had that same problem with RC3 and it blew my hard drive away along with all data. I guess you should have waited until it was released, huh?
doneedlove
1,135
hi,
I did format eveything and reinstall it from scratch.. still have the same problem as i get to the 10 min left... well, it's too much problem caused by winME so i said forget it.. ahhah. .WIN 98 for me as long as i live.. hah.. bye.
take care,
DoneedlOve :)
Bleeding Jawa
1,392
WinME is running beautifully on my my Asus P3V4X (VIA). No problems installing. No problems with drivers or anything.
travis82
4
Ya...I had the same thing happen...it took mine about 5-7 minutes to get past that part. Just leave it sit there for a few minutes to see what happens...should work
XNice
1,562
I am with jawa, I upgraded from Win98SE using a bx board. I installed my Asus P3V4X and it booted up fine, THE FIRST TIME! Anyway get an asus and winme will run fine. I will be doin a clean install as soon as the public version gets into stores.
doneedlove
1,135
hi,
nope it froozed on me for 1/2 hr or more so i decided to go back to my own trick of win98
take care,
TnT
