Problem installing VIA Apollo Pro133 drivers ... Help!!!
ZM
53
Good Day,
I would like some help/suggestions on this matters please ... :)
I bought a PIII733Mhz FCPGA, and a board ... a Supertek ST-693AVMA/E (VIA Apollo Pro133). I installed Windows98SE, it all went well.
I have a Diamond Stealth 3D 4000 4Mb Memory ... a bit outdated, I know but ... :( ... I will change soon ... :) ... waiting for christmas ... $$$ :)
I also have a Network Card (Realtek something), and a Diamond Supra 56i modem.
I have 2 hard disks, 1 CD-ROM and 1 iomega Zip 100 (IDE internal). After installing windows, I installed the software which came with the board, the VIA 4-in-1, IRQ Minidrivers, AGP ... , and the audio drivers (for the built-in audio device).
The last drivers I installed where brought the problem. After installing the IDE device drivers, and making a reboot as requested, the windows simply refused to detect the CD-ROM and ZIP drives ... there I was, with access to only the Hard Drives (besides the Floppy Drive).
I also noticed that before the installation of ANY drivers provided with the board, the computer was running quite a bit quicker that without any drivers installed, especially with HD accesses.
What can I do about that?
Is it possible I could not use the drivers provided with the board?
What can be the repercutions of not installing the drivers? Windows detects the VIA controllers, the USB, but I don't know if it can take the most out of the board without the drivers provided ... :(
I had 2 "PCI Comunication Devices" on system properties/Hardware, with a big yellow question mark. After installing the Modem drivers, I remained with just one ... but I don't know what device it is ... the network adapter seems to be ok, windows detected it and installed the drivers itself ...
Please give me some help ...
Many Thanks!
ZM
SuperDaveDCF
20
The readme for Via's drivers specifically say not to install the IDE bus master drivers if running Win 95/98.
ZM
53
Thanks for your help :eek:
Any opinion about the other points? The performance before and after the installation of the drivers and the "PCI Comunication Device"?
Thanks alot! :)
ZM
