I'm trying to install the Enermax EG465-VE into my Lian Li PC67, and the screws aren't aligning properly. Should I just tape in the Power Supply? Thanks
You have to turn the powersupply upside down. In some Lian-Li cases, the bracket where the PS connects to the back of the case can be removed and flipped around so your fan is pointing the right direction.
<< You have to turn the powersupply upside down. In some Lian-Li cases, the bracket where the PS connects to the back of the case can be removed and flipped around so your fan is pointing the right direction. >>
