Problem installing new SATA drive
CompGuy18
8
I have asus A8V-E Deluxe motherboard with the latest bios 1012. I bought a Seagate 400GB SATA II hard drive (ST3400633AS-RK). I have tried installing the drive as a second hard drive with my primary ATA133 maxtor with windows xp already installed. I also tried installing it as a standalone drive with the maxtor unhooked. Both times my computer cannot recognize the drive.
I have used the cd which came with the sata drive and tried installing it from windows and then as I said booted with the cd with my other hdd unhooked. The only setting i can find in my motherboard bios is an option to run the drive in RAID or IDE. I tried both settings. When it is set to IDE. Neither work.
Im not sure what to do from here or what im missing.
Thanks.
V00D00
1,834
Are ALL of your motherboard drivers installed? Is the SATA disabled in the bios?
CompGuy18
8
Yes I installed all drivers.
Edit:
There are two options in my bios for SATA
First, onchip sata controller enable or disable
I have that enabled
Second, I can toggle sata from RAID or IDE
CompGuy18
8
Also When I have the SATA drive connected to my motherboard and get into windows on my primary drive, in device manager there is a yellow error sign for the VIA SATA Raid Control. I have tried to reinstall the drivers that came with the motherboard, also updated from asus site, and tried the cd which came with the SATA drive. Nothing works.
CompGuy18
8
I may have found the problem. Someone on another board said my motherboard does not support SATA II. Is there a pci controller card I can get so it would be supported or do I have to return the hard drive for a SATA I?
V00D00
1,834
Sounds like a driver issue, but it seems like you've already thought of that. Do you have any other SATA drives you can attempt to use? Maybe it's a bad drive. If you can find different versions of the drivers you installed try that. Maybe older drivers will work.
Do you see the drive when the computer starts up on the "scanning drives" and whatnot screens? Or does the bios have a screen that shows the drives that are attached?
You can download the ultimate boot cd from here: http://www.ultimatebootcd.com/ and see if any of the partition managing apps recognize the drive.
Try a different cable and power connector as well... who knows, could be anything. I'm sure you've tried it on a different SATA port on the mobo as well?
Paperdoc
2,455
350
I assume that, in your BIOS when you set the controller to enable SATA and treat it as IDE, the BIOS indicates that it recognizes the drive and shows some reasonable parameters and a correct size.
Have you partitioned and formatted the drive? Every new drive needs those two operations done before it can be recognized and used by Windows. You mention the drivers that came with the drive, so I assume you have a software CD. It should have an installation utility to do these jobs.
Partitioning is the first step. IF you have SP1 or SP2 as part of your Win XP, then you can handle HDD's of any reasonable size. You have the choice of making one large partition on the HDD, or two or more smaller ones. BUT if you have only the original XP with no Service Pack, it will only allow HDD volumes to be up to 137GB (actually appears to be about 125GB once it's all done and reported by Win XP). Then you will be forced to make several partitions, each treated by Windows as separate drives with their own names.
Once a partion (or more than one) is created on the drive, then you must format each one to create the blank file system on it. I'll warn you that Windows takes a VERY long time to do this because it does a careful check of everything as it works. The drive maker's utility disk proably uses a simpler "quick format" that can do the job in a couple of minutes per partition.
You may be able to do all this, instead, using Win XP's tools. Do Start ... Settings ... Control Panel ... Administration Tools ... Computer Management ... Disk Management. It will show you all your drives, including a display of a blank box indicating a disk drive not ready to use and undefined. Right-click on it and look for a tools to create a partition (you can specify the size), then another step to format it. If you made your first partition smaller than the whole drive, go back and make another in the remaining space, then format it. Once these are done, if you right-click on the useable drive, one option available is to change its name if you want to control the way all your drives are labelled.
Oops, I forgot one little detail to check. I don't know if your mobo's controllers support SATA II, or only the original SATA. Many new HDD's come with a small jumper installed on pins on the back to limit it to work on original SATA controllers. If that is what your controller does, look for the jumper and labelling near it. But if you have a newer SATA II controller you can remove the jumper and make the HDD perform as a true SATA II. The only snag that can come up is if you have a plain original SATA controller and your HDD does NOT have the limiting jumper installed. Then controller and HDD don't talk well.
