- Dec 2, 2004
- 12
- 0
- 0
Ok, I got my A8N SLI mobo, I've got my new Antec P160 case and I've got most of my accessories. I'm ready to rock & roll.
I unpack the mobo and the case and as I go through the process of installing it on the mobo tray, I notice 1 thing. Neither manufacturer supplied screws. I shrug it off and go scavange off a dinosaur. I try to get everything to line up with the rear panel. And after some light fidgeting I get it to fit(mostly). I noticed a few things though.
1.) Do we not need risers anymore (between the mobo and the mobo tray)? Neither book mentions them. The ASUS book only talks about the 9 screws (which weren't included in the packaging). It seems to me that with the 1/8" that the existing screw holes would provide that we'd have all the soldering touching the back-plate which seems like a big "no-no" to me...
2.) The back edge of the mobo tray (below the rear panel) is positioned in such a way that I would need something in between the mobo and the tray or extra long screws. This just doesn't seem right and makes me think I need risers.
Since neither company decided to include them, am I missing something or should I have purchased some? If so, where's a good place to get them?
Thanks!
Thanks!
