Problem Installing MS Visual Studio,please read!
dezell123
Banned
Dec 14, 2000
554
When I try to install MS Visual Studio,(Microsoft Visual C++,and the data access are the only I have clicked,if that helps),it goes through everything,and then,when it gets to Setup is Updating the system,a popup pops up,and it says:
Setup has encountered a problem in launching the following command line: (here are two semi thick black lines,I dunno what they are).
If you have a system directory that contains a % sign,or the directory name starts with a space(i.e. 'C:/win95/system'),then setup will fail. Please restart setup and ensure your system directory name does not contain the aformentioned problems. Setup will now abort...
I checked,and my windows/system folder doesnt have a space before it,so,I don't see what the problem is..
Thanks for any help! :D
Azraele
16,524
29
Try posting this in Technical Support or in the Software Forum. You'll probably get more answers there. :)
