Problem installing hard drive on Dragon+
mritz
I just received my replacement hard drive from Maxtor and trying to get
it to install with no luck at all
I have a Dragon + And Athlon 1700+ XP Windows XP
I have my CD and DVD set on IDE 1 (set Master/Slave)
CDRW on IDE 2 (master)
Boot drive is a WD 20g on IDE 3 works good set for( MASTER)
Storage drive is a Maxtor 6L080L4 80g ATA133 7200rpmIDE4 (master)
The 80g drive detects in the Promise Bios just fine Windows XP finds the drive
and trys to install it but keeps telling me it could not install the drive
An error occured durring the instalation of this device
one of the filter drivers installed for this device is invaild
If I look in device manager it shows the drive yellowed out but I can go to
My Computer or Explorer and read and write to the drive ??
I had a 30G Maxtor installed and pulled it to install the 80g and the 30g
worked fine I have tried everything I can think of with no luck
I verified that the correct end of the cable is on the board
I have tried NEW ATA100 cable's and have switched my drives to
IDE1 W/D 20g ATA100 7200
IDE2 Maxtor 80g ATA133 7200
IDE3 CD rom and DVD
IDE4 CDRW
Same results the 80 g shows yellowed out and every time I reboot XP tries to reinstall it 🙁
Well I tried everything I could think of and then some 🙁
I even started having the same problem with my Boot Drive(20g W/D)
after moving things around
I finaly did a full install of XP and the drives are installed BUT if I move either of my
hard drives I end up with the same problem all over ?
I tried setting them a Master and Cable select with NO change
this is a very weird problem to say the least
I can move my CD rom DVD or CDRW with NO problems redetecting and installing
I only have problems with the hard drives
