im not cr0ss p0stiing . but i didnt had any good reply in other forum and it was mistakenly posted on gen.hardware.
BUT PLEASE HELP ME WITH THIS
My current VGA is ASUS FX5800 non Ultra card with 400core and 800mhz mem.
I dont overclock it and always it is at about 48'c, and 65'c temperature @ maximum.
but couple of days ago when I was using WinXP (not any 3d work) some areas of my screen showed some hundreds of small squares (about 4 x 4pixels in size)
when I tap my cpu case it was changing
I restarted and from the boot screen the squres were there and it only shows them in colour background, DOS and other text were normal.
i thought the AGP port was loose, but in other motherboards also this problem came.
And I use another VGA on this Mboard, it worked properly.
when i shake the casing the problem getting worse.
so please help me, Im g0ing to the dealer (i used it over 1year+ but got ASUS 3yr warranty)
any thing to check/ do before go??
I really love this CARD and i will have lots of problems to warranty claim, (thaey dont have a good money worth vga now and got those 6600LE 256MB s)
Thanks.
Thanks.
