I've got two of these adapters showing in my device manager. Both with error code 10. Windows can not repair. And I can not remove them from the system. Anyone know anything about these devices upder the Network tab?
Code 10 means device is not correctly attached. Removed both software and hardware then reinstall the software and make sure insert the hardware on different slot if it is possible!
