Problem in 3dmark 2001 with Kyro II
Jesus12
7
Hi everybody
I've got at slight problem, my computer freezes whenever i try to run the 3dmark2001 benchmark. I can run the lobby scene without freezing (both high and low), and the car chase in low res. I have no problem running the cow game.
Is this a problem there is going to be solved with directx 8.1
All games e.g. Q3A, CS, Delta force 3, etc. run perfectly.
Anyone else got a similar problem og even a solution.
My system is:
Duron 800@969
Chaintech CT-7AJA
196 mb RAM (PC100) CL2
Hercules prophet 4500 tv-out (64 MB)
Jesus
Garet Jax
6,369
Jesus,
Did you do a fresh install of your OS or did you change video cards and re-install the drivers?
Jesus12
7
Hi
I tried it, and it didn't work.
I found out something funny. When I've just installed the drivers I can run 3dmark 2001, but when I have rebooted i dosn't work again.
However it dosn't matter that much since every game runs perfectly.
Jesus12
7
Hi again
I tried lowering the FSB, and it actually worked. know I can run the benchmark with one exception the high polygon count test. If i run it as a single test i will run fine.
It crashes both in 3dmark 2001 and 2000 (only when using directx T&L).
I have tried running other high polygon tests, eg. GLExcess1.1, and it runs perfecly. I don't know if the final directx 8.1 will fix this.
vss1980
2,944
I thought there was a problem with DirectX 8.0 and 3DMark2001 on the Kyro (DirectX errors - not card)?
From what I've heard, the up-coming DX 8.1 should fix this.
Jesus12
7
I am using directx 8.1 build 620, so I'm just hoping that the final version will fix the problem.
