Ok, to make it short it started here: http://forums.anandtech.com/messageview.cfm?catid=32&threadid=232092[/L]
I tried everything I knew. Because of other problmes, like startup disk came up with missing files command.com, it wouldn't work. I also tried copying the file from floppy. Worked but didn't overwrite the old so didn't help. I could go on and on, but here's the deal, I finally succombed to formatting and reinstalling.
the prob now is that there is NOTHING on start up, not even start up! (after formatting) From power up it tries to read the floppy, then gives "Invalid system disk Replace the disk, press any key". This can't be good. It's set as hard drive for first read. If I use a startup disk it will come up with this:
"The following file is missing or corrupted: HIEMEM.SYS
There is an error in your CONFIG.SYS file on line 24
Microsoft RAMDrive version 3.06 virtual disk D:
RAMDrive: Extended Memory Manager not present
Warning: the high memory area (HMA) is not available.
Additional low memory (below 640K) will be used instead
The following file is missing or corrupted: command.com
Type the name of the Command Interpreter (e.g. C:\Windows\Command.com
A>"
Well, that's it. I believe all this other stuff is cause of the start up disk. So I don't even have dos now. I formatted using C:|format/q (quick format)
Can anyone at least point me in the right direction? The next step I can think of at this point includes fire and marshmellows!!
Thanks
A>"
Thanks
