- Oct 12, 2003
- 417
- 0
- 0
Hello all,
I hope some could help me on a problem I am having with the memory I installed on my ASUS Rampage III formula motherboard. I installed 6GB Corsair Dominator 1600mhz memory and on the bios/system info/ and control panel system screen it only shows 4GB. I'm running Windows 64-bit professional so I know it should at least read more than that. I've already tried switching the memory with memory sticks (Corsair XMS3 6GB 1600mhz) and still I only see 4GB. I also looked at the socket pins if anything is bent (hard to tell exactly what is considered a bent pin, since all the pins seemed angled at one direction *dunno if that makes any sense*) and then it showed only 2GB, so then I re-applied the CPU then it went back to showing 4GB and not 6GB. I researched the best I could online from some others who have had similar if not exact problems, who had some remedies but still only show 4GB. I know at least the memory itself is only because it shows 6GB in my other i7 rig and that this memory is listed in the compatible memory-motherboard list, but what gives? Is there something I missed? or something that I have to configure in the bios? or *I truly hope its not* the motherboard itself?
