problem connecting to CCTV
strike101
Need a little bit of help here guys , can't connect to my CCTV @ my shop
here's a simple diagram of my network
Q1> How to i connect to those CCTV's ? from a remote source ?
You'll have to connect to the outside, public IP 205.23.245.XX but you will want to set up the router to forward all connections on a certain port to the CCTV. I would set it to a private port >= 49152 if your CCTV system doesn't have a specific port that it uses. You can get more info on specific ports here.
What kind of CCTV system are you using?
I reread your question and my first response is how to access from a remote location. And I just saw that you have 2 cameras. You'll probably have to assign each of them a different port unless they come with some sort of management program that allows you to view both at the same time.
