- Nov 14, 2005
- 1,431
- 0
- 76
I burn a lot of dvds because I author a lot however recently I cant burn dvds anymore and I keep getting burn process errors with Nero 7.
I thought at first it was just the format but to no avail.
Irony is however that cds burn perfectly fine
So here is the log it gives me.
Any ideas?
thanks
Any ideas?
thanks
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: <TSSTcorp CD/DVDW TS-H552B>Version: TS04 - HA 1 TA 2 - 7.0.0.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD2000JD-22HBC0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prtBak Port 5 ID 0 DMA: Off
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7aVax347sBak Port 6 ID 0 DMA: Off
=== CDRom-Device-Map ===
Generic DVD-ROM E: CDRom0
TSSTcorp CD/DVDW TS-H552B J: CDRom2
SCSIVAX DVD/CD-ROM L: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096428kB)
Free physical memory: 1506MB (1542996kB)
Memory in use : 26 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.11.2005
UDF/ISO compilation
1:47:54 AM #1 Phase 112 File dlgbrnst.cpp, Line 1724
DVD-Video files reallocation started
1:47:54 AM #2 Phase 114 File dlgbrnst.cpp, Line 1724
DVD-Video files reallocation completed (no file modified)
1:47:54 AM #3 Text 0 File Isodoc.cpp, Line 6410
UDF document burn settings
Determine maximum speed : FALSE
Simulate : TRUE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
1:47:54 AM #4 Phase 111 File dlgbrnst.cpp, Line 1724
DVD-Video files sorted
1:47:55 AM #5 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
1:47:55 AM #6 Text 0 File Reader.cpp, Line 124
Reader running
1:47:55 AM #7 Text 0 File Writer.cpp, Line 113
Writer J: TSSTcorp CD/DVDW TS-H552B running
1:47:55 AM #8 ISO9660GEN -11 File Geniso.cpp, Line 3304
First writeable address = 0 (0x00000000)
1:47:55 AM #9 ISO9660GEN -11 File Geniso.cpp, Line 3304
1:47:55 AM #10 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using DVD media
1:47:55 AM #11 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1565503 (347:53.28, 3057MB)
1:47:55 AM #12 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
1:47:55 AM #13 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: TSSTcorp CD/DVDW TS-H552B, Media type: DVD-R
Disc Manufacturer: MXL RG - 03
Disc Application Code: 64, Disc Physical Code: 193
1:47:55 AM #14 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
1:47:55 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1565504 (1565504) = #1565504/347:53.29
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1565504 blocks [J: TSSTcorp CD/DVDW TS-H552B]
1:47:55 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [J: TSSTcorp CD/DVDW TS-H552B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3206152192, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1565504 | lead-out | 1 | 0x41 | 0x00
1:47:55 AM #17 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
1:47:55 AM #18 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
1:47:55 AM #19 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
1:47:55 AM #20 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
1:47:55 AM #21 Phase 32 File dlgbrnst.cpp, Line 1724
Simulation started at 2x (2,770 KB/s)
1:47:55 AM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
1:47:55 AM #23 Text 0 File DVDR.cpp, Line 2469
Recording mode: Sequential Recording Mode
1:47:55 AM #24 Text 0 File MMC.cpp, Line 21541
Set BUFE: Super Link -> ON
1:47:55 AM #25 Text 0 File DVDR.cpp, Line 2624
Start write address at LBA 0
DVD high compatibility mode: Yes
1:47:55 AM #26 Text 0 File Cdrdrv.cpp, Line 8385
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1:48:01 AM #27 Text 0 File Cdrdrv.cpp, Line 1195
01:48:01.781 - J: TSSTcorp CD/DVDW TS-H552B : Queue again later
1:48:02 AM #28 SPTI -600 File SCSIPassThrough.cpp, Line 306
CdRom2: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 02 60 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x04b10000: Len x10000
0x00 00 01 BA 44 00 0E 41 26 29 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 86 84 92 C9 B8 0C 66 4F CE
0x27 D3 6B 6B 86 62 15 00 67 C3 02 06 BF 57 76 15
1:48:02 AM #29 CDR -600 File Writer.cpp, Line 302
Device not available
1:48:02 AM #30 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
1:48:02 AM #31 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
1:48:02 AM #32 Text 0 File DVDR.cpp, Line 2866
EndDAO: Last written address was 607
1:48:03 AM #33 CDR -1114 File WriterStatus.cpp, Line 167
Reset occurred
1:48:03 AM #34 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
1:48:03 AM #35 Phase 34 File dlgbrnst.cpp, Line 1724
Simulation failed at 2x (2,770 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=3.00.09a, size=46080 bytes, created 8/19/2005 2:00:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 8/3/2004 9:59:42 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
