I just bought a bunch of DVD+R DL discs and have been doing some burning (the discs I bought are Ritek RiData D01 white inkjet printable). I have a bunch of ISOs that were ripped as exact copies-no compression, no restructuring, etc. The DVD burner I am using is a Pioneer DVR-108 retail, using Nero 6.3.1.20. When I burn the disc, I simply do Recorder-Burn Image, select the file, and burn. It seems to work ok, the disc even comes up when I put it in the player to play it, but then while it's being played it freezes around where the layer transition should be. I burned about 10 discs yesterday and every one of them is doing the same thing. I just tried burning using DVDDecryptor, with the same results. I have been able to do a successful burn with Verbatim DL media using the same procedure with Nero. I haven't found any incompatibilities listed with this media and my drive (it has the 1.20 firmware on it).
Does anyone have any suggestions? At this point I've wasted over a dozen DL discs, and I don't want to keep trying, but I can't figure out what is wrong.
