Problem burning a 4.2 GB file.
SIEva
8
I'm trying to burn a 4.2 GB file to a DVD-r using Nero and then Burn Data DVD, but when I check the file on the DVD it is only about 200 MB.
I have burnt it twice now with the same result.
What can I do to get it to burn right?
Thanks.
mzkhadir
9,509
does the whole process go fine without a hitch ?
Does it error out and with what error ?
SIEva
8
No, thats whats weird, it fineshes and says "Burn Successful".
But i've done it twice.
I just noticed that when you select Data DVD it burns as an ISO, should I be using UDF or UDF/ISO?
SIEva
8
I have Nero on 2 computers and they both say that.
It burns a data dvd as a "DVD-ROM (ISO)"
I kind of remember there being a limit on file size with burns like that?
Is it ok to burn files a UDF or UDF/ISO?
mzkhadir
9,509
You should be able to use UDF/ISO to burn, but I havent used that option in the past ever. So you will have to try and find out.
