Problem booting up in WinXP
SP33Demon
27,928
143
Ok, everything was perfectly normal last night after turning off the computer. I turn it on this morn, and while booting, it doesn't seem to be recognizing my Verbatim CDROM. On loading it shows up like w3%@#VeRbAt$@IM!!%#$%$#!!, not exactly like that but close. I try to boot in regular and safe mode, and it halts at mup.sys, and I can't boot off the CDROM b/c whatever happened to my CD Driver is probably now corrupted.
I was thinking that this may be a virus? The funny thing is that I just scanned everything using updated Norton, Spybot 1.3, and Adaware SE and everything was fine.
My specs btw:
WinXP Pro SP2
Verbatim 48X CDROM/burner
DVDROM (not hooked up though)
1 Gig Corsair RAM
BFG 6800 Ultra
Athlon XP 2600+
Gigabyte GA-7N400 nForce 2 rev 2 board
I just installed XP last week, so I doubt it's a compatibility problem. Everything was working great. Any help would be appreciated. :)
montag451
4,587
If you have a usb card, take it out.
then try it.
Otherwise, take out all non essential hardware, only keep hdd, vga, cpu, ram, cd... disable all onboard integrated periphs.
Try that
Chunkee
10,391
your cd rom has gone kaflooey
no biggie
swap it out and see if that remedies it.
i bet it does
jC
