OK i'm running Windows XP and today my computer froze. When I turn it on now, it goes to this blue screen that says :
A problem has been detected and windows has been shut down to prevent damage.
*UNMOUNTABLE_BOOT_VOLUME*
Check to make sure any new hardware or software is properly installed. If this is a new installation ask your Hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed Hardware or software. Disable BIOS memory options such as caching or shadowing.
TEchnical Information STOP:* 0x0000000ED
The thing is that i can't even boot up on safemode, last good configuration, or normal mode. The blue screen keeps on coming up everytime i try to restart.
