The system with GA-B85M-HD3 did not start after power outage.
Internal speaker makes some sort of ticking noise at constant slow frequency.
The fans are spinning and the power led is on.
I disconnected all HD & SSD drives and tried only with CPU and RAM but no change.
Now it gets interesting.
Took out the RAM, and powered up. I get endless beeps.
Put back the RAM, system now powers up just fine. no ticking or beeping.
Power off and restart and the ticking is back.
Power off, remove RAM and put it right back. system powers up fine.
Reconnected all HD & SSD drives, removed RAM and put it back.
System came up fine and works like a charm.
I can restart from windows and system still comes up fine.
If I shut down and system is powered off, it will not restart unless I remove the RAM and put it right back.
I tried with different RAM stick and still same behavior.
So is this a bad MB or what else could it be ?
