- Oct 26, 2000
- 4,749
- 1
- 0
Guys,
Good Morning, I need your advice and expertise. This motherboard is getting on my nerves. After three rma's, this motherboard still does not work. When I put a processor, like the pentium III 550 into the slot1, there is a constant beep which repeats ever 5 second intervals without stoping. I even tried another processor a Celeron 450 slot1 and it has the same problem. I know both processor works because i've tested it on my other system. All the components i'm going to use for this computer is test and works. I gotten to the point, where i just plug in the processor, and turn power on and the beep still occurs, nothing else is in there. I tried many different combinations from processor, ram, video card, to processor ram and so forth. Nothing changes.
What should i do, should i yell at ABit or just get a new board. Need advice.
Thanks
good luck
ManSnake
Thanks
good luck
ManSnake
