I just purchased a TI-83 Plus graphing calculator and a usb link cable. i installed the ti-connect program. it notified me that there was an update to the operating system available. i started the update. it was 14% done and the power to my usb hub cut out because i bumped the power cord. so the update stopped and it didnt connect back to my calculator. the calculator screen then read:
ERROR!
Press any key to
turn unit off.
Then turn unit
back on.
After doing so, this screen came up:
Waiting...
Please install
calculator
software now.
when i click to restore my old files (i saved them) or when i click update, the computer tells me that it cannot connect to my calculator and the calculator just gives me the error screen again. what should i do?
btw this was in tech support but it doesnt realy have to do with comps and no one was replying so i moved it here.
EDIT: problem solved
ERROR!
Press any key to
turn unit off.
Then turn unit
back on.
Waiting...
Please install
calculator
software now.
