pro-scan, dual-voltage, PAL/NTSC DVD player for $43.86 at Walmart B&M
hyderabadi
68
This CyberHome CH-DVD 300S Progressive-Scan DVD (Silver) player is also hackable (with remote control codes available on the 'net) to play DVDs from all regions. Plays DVD-Video, DVD-R, DVD-RW, DVD+R, DVD+RW, CD, CD-R, CD-RW, SVCD, VCD, MP3, etc. After buying this I have retired my non-progressive-scan Norcent DP-300.
Mehdi
67
This DVD player has all the features I'm looking for, exept an LED display. For those interested, here are a couple of pictures:
Front View
Back View
Remote Control
This is probably not a good place to ask, but can anyone recommend a player with this set of features that does have a front panel LED display?
dougtran
70
Bought two of the 500 series, and both had problems. You can't beat the price/feature ration but quality is lacking. Make sure you can easily return it.
Doug
Kostya17
348
Originally posted by: hyderabadi
This CyberHome CH-DVD 300S Progressive-Scan DVD (Silver) player is also hackable (with remote control codes available on the 'net)...
Where is the link to codes?
GAZZA
1,987
Anyone know if this is region free ?
nm just did some readin up on that forum !
Richard98
1,093
Doug
Yup, same here. My CH-500 started locking up, skipping, etc after about 6 months. Warranty on mine was 90 days labor, 1 yr parts. Not worth fixing.
hyderabadi
68
Yes, it can be made region-free. I have set it to region "0" and have watched "region 1" and "region 2" DVDs on this player.
