Private IP address problem
CurtCold
1,547
I have 3 computers on my home network. I use a switch for my cable connection. I have one computer that I can see on the network, and transfer files to and from, but will not access the internet.
I'm sure the problem is the fact that XP keeps assigning the computer an "Automatic Private IP Address." All the settings are the same as my other 2 computers, but I cannot get rid of the Private IP addy. If anyone can tell me how to change it I would appreciate it.
Thanks
Specs
2100+
A7v266-e
60GB IBM
GF2
Win XP sp1
JW310
1,582
Are you using a switch or a router to share your internet connection? I know that many cable ISP's only allow one computer to access the internet. Some (such as TW RoadRunner in my area - Troy, NY) allow 3 computers, and thus a switch should work, but in most cases, one needs a router to share a cable internet connection among multiple PCs.
JW
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
It sounds like the cable company is not giving you a DHCP address. How many are allowed on your account? Do you have to pay extra for additional addresses?
The 169.X.X.X addresses are used when no DHCP address has been received.
Check your account to see if you should be getting more addresses or put in a router. The router will allow you to have many addresses behind the device while only using one "outside" address.
Check your terms of service first, they may not allow you to add the router under your existing terms.
Good Luck
Scott
