Printer setting is in Potugese - I need english!!!!
BigVan
How do I cahnge my setting of my Printer - I loaded the wrong driver now everything is in Portuhese - that is fine but I don't talk portugese. I tried to un-install the driver etc. Evry time I load new driver the settings is in portugese. Please help!!!
corkyg
Elite Member | Peripherals
27,370
239
Go to HP's site, enter your specific model and download the English driver set. They are by language.
HP
david46675
404
HP
or learn portuguese...might be faster than the download from HP :p
LiLithTecH
3,105
HP
Unfortunately just installing another language does not work.
Especially if it is a 3500 or 3600 series.
You need to REMOVE Every Last Trace of the old driver.
DLL(s), Registry entries, software.
corkyg
27,370
239
HP
Yes - that is true even when changing some drivers in the same language. H-P drivers are not that hard to remove - but you are right - you have to scrub the system and start over. That means completely uninstalling the printer, then scrubbing all folders and vestiges in the Registry.
As for learning Portuguese - not a bad idea. I once worked as an interpreter in Brazilian Portguese. :)
