Do you have an older style AT case configuration? It could be that either the ribbon in the computer that attaches to the board came loose, or it is just a bad port. If you have ATX, and are having problems, I'd probably try downloading the newest drivers. Do this either way.
Russell "MR.Bios" Sampson
