printer problem
aznglow
i know this is must be an old topic for a lot of people
since i had this problem for a long time
when i put a print job
and cancel it, my printer will still print out as much as info OS has sent to it
so canceling actually makes it to print just JUNK
how do i completely remove it from the printer?
thanx
Turn it off, then on again to purge the on-board memory.
Some printers may have a button, possibly on the back, to do the same thing. Check your documentation.
I'm not sure if this would help or not, but it might be worth a try. Change the printer settings to "Print directly to the printer" instead of "Spool print documents....".
I usually just turn off the printer, delete the print job and then turn it back on.
Usually works.
