Printer Help
NumbersGuy
528
After some harrowing fighting with my computer, Partition Magic and what not, I noticed a second entry of my printer, say "K-80" & "K-80 (copy 1)"
Renamed the second as "DRAFT", changed properties to print, cleverly enough, drafts.
They operate as different printers, with different settings, while being of course the same machine.
Q: How do I repeat this. i.e. making duplicates of printers.
Tried unsuccessfully: copy/paste, add a printer (from network and local machine), add shortcut (leads to same printer)
How??? Wizards???
Thanks
P.S. No help from Peripherals forum, should have started here; maybe it always belonged here!
montag451
4,587
Hi,
You just Add printer from the wizard.
Install the driver when asked, then rename the profile, and set it to how you want it to print.
