This is a common issue that I've seen in plenty of environments. Currently my parents have it bad.
Laserjet printer plugged directly into an outlet. UPS with the computer plugged into another outlet on the same AC leg or circuit. No option to plug into another circuit as there is none near.
When the printer fuser kicks in, it causes a brownout on that AC leg but the UPS does not switch fast enough, or when it switches it just switches right back, and does this several times. This causes such a distortion in the AC wave that it causes the PC to shut down. Does not always do this, it's random. I think what happens is because it's not a true AC fail situation the UPS does not react properly. Only way they can print is if they flick the power bar off to force the PC to run off the UPS.
From all these bad shutdowns their PC is now acting up. Shutting down on it's own etc... Before I even fix whatever hardware has gone bad (PSU I'm guessing) I need to figure out a solution to this.
Their UPS is an APC 1000, fairly new. At this point I'm willing to even buy a new UPS. Or is there something else I can buy to fix this problem? Some kind of power filter, capacitor bank?
Worse case scenario I'm thinking a battery charger hooked up to an inverter, with a battery. Heck my dad sells RVs, maybe he'll have some of that stuff at the store he can get cheap. I'll have to ask. Only thing is I'd hate to set something like that up and not properly monitor it. Need to find a decent amp charger though, like at least 30 amps or so.
I'm also weary of blaming the wiring, as it's not that old of a house so it has a proper panel, and the basement was redone maybe 15 years ago. House is 27 years old. So it's all romex wire, proper sizes etc..
Though, that circuit IS also GFCI protected at the bathroom. Could this somehow have an effect? I can't see why though.
