- Aug 25, 2001
- 56,587
- 10,225
- 126
Ok, I've been tearing my hair out (well, thankfully not quite literally), trying to keep my R5 3600 CPU cool, while crunching 12 threads of PrimeGrid PPS LLR.
At this point, I would like to see other people replicate my setup, and see what their temps are.
I've used both a Gigabyte B450 AORUS PRO WIFI ATX, with both AGESA 1.0.0.2 (BIOS F40) and 1.0.0.3AB (BIOS F41b), and an Asus B450-F ROG STRIX Gaming ATX, with AGESA 1.0.0.2 (BIOS 2501).
I've tried both stock settings, as well as a mild 4.000Ghz manual OC with 1.365V, using the "AMD Overclocking" menu, "manual OC".
I've used both 4x8GB DDR4-3000 @ XMP, as well as 2x8GB GSkill RGB DDR4-3600 (with FCLK 1800 as well), in current setup (Asus B450-F).
I've used four different air coolers, as well as finally, on current rig, 240mm AIO WC (CoolerMaster). Still 97.5C running 12 PrimeGrid tasks. On water. Before the water even got a chance to "heat up", after being idle all night, 44C idle temp.
So if you would like to replicate, if you have a 3600 (or higher) 3rd-Gen Ryzen CPU, head on over to http://www.primegrid.com/ , sign up for an account, and download BOINC, from boinc.berkeley.edu , newest version for Windows, and then "Add Project", put in your PrimeGrid credentials. Note that you should also go to your PrimeGrid account page, on their site, and select "PPS LLR (CPU)" as your project type, and uncheck EVERYTHING ELSE.
Then in BOINC, under "Compute Preferences", make sure that "CPU count" and "CPU time" are both "100".
Edit: Oh yes, you should be running Win10 1903 64-bit, and download and installed the newest (7/7/2019 release or newer) AMD Chipset Drivers, and also, newest AMD Ryzen Master. Measure temps with Ryzen Master.
Edit: Btw, does anyone know, does the Ryzen R5 3600 use TIM/paste, rather than solder, on their lowest-end model? I suspect that they might.
