Prime 95 experts-READ pls.
LIVAN
1,210
Anyone know what a SUMOUT error means? If I get it, does it mean the same as HArdware failure?
Ching
23
Yup, yours system is unstable. try to raise the voltage just a little notch. Your CPU need more juice ;)
xcourse
224
If you get to the point where no voltage increase or anything else allows you to run the program without having it halt because of "sumout" or rounding errors, then you've reached the stability limit of your system and need to back the cpu multiplier or fsb down a little. Good luck.
