- Jul 7, 2007
- 41
- 0
- 0
Hey everyone. This is a long story. It's been a long day.
So here's the thing. The PC worked up until yesterday, beforfe I took it apart and brought it over. Today, before booting, I decided to remove the dust and install the backup HDD. Then when I pressed the power button, it wouldn't boot!! Since then, I've discovered a few things. The drive which had the OS (Win 7) will not boot. I assume the drive is fine, because it's recognized by the BIOS.... At least with one set of cables, the ones that the OTHER HDD was using. If I try to plug it in with the cables it had yesterday, the HDD doesn't even get power (details don't show on the BIOS screen)
So here's my set of hypothesis on why this thing is malfunctioning:
1. I added a second WD1001FALS, which I planned on using as backup, today
2. I vacummed the PC's entrails (using the long tube). I also used compressed air for the hard-to-reach spots
3. HDD is dead?? (NOOOOOOOOOOOOOO)
4. ?????
Now here's the kicker: the drive is partitioned, which I hear is good news whenever you have an issue like this. I already installed Win 7 on the 2nd HDD, but I can't do jack about it since the other drive isn't coming on with that set of cables. I replaced the cables (I had some spares) and the HDD still didn't come on. Could this be a motherboard issue?
To make matters worse, I called Dell (their XPS support comes from the Phillipines). Not much issue communicating, except that they seem unwilling to help me if I'm not talking about the original HD/OS, and since both upgrades I purchased from NOT-Dell, I ultimately ended up telling them everything had failed and so they're sending a Tech with a new HD and cables. I plan on telling him what I need and hopefully (s)he's not a robot.
But what can I do?? Could it be I ruined the drive (unintentionally)? I don't think it was a huge deal. The air compresser hit for maybe half a second (it did spray on the MB for that half second), but I don't think that could ruin it. Dell didn't think this is a MB issue, they said that if that's what it was, I wouldn't be able to see the "Primary 0 drive not found" error.
HELPPPPPPPPPP
4. ?????
HELPPPPPPPPPP
