This was previously in the "Cooling issue on P4" thread but the problem has changed a bit...
please read on....
It hasn't anything to do with Hard drives, windows, device database or anything.
It will hang just sitting idle in the bios screen--- before it even gets into the "meat" of booting.
A kind soul- and you know who you are- pointed me toward the fact that the 1002 bios on the Asus board reports the wrong temp.
I actually was able to get the board to boot into Dos long enough to flash the bios to 1003 and now the temp readout is correct. It reports 39 degrees C which is about what I would expect for a lower-end heatsink.
Upon further investigation, I still have problems.
I have tried both PCI and AGP cards. I have tried different combinations of RIMMS- even did a long post where the memory was checked continuously without any errors.
The motherboard temperature reading is only a couple of degrees over room temp so I don't think it is the mobo having heat probs. (The northbridge does have a heatsink on it that isn't exactly centered but it is on well enough that I doubt very seriously that could be a problem.)
I am at a complete loss. I have been building systems for 15 years and have never had this much problem with a system before. In the past it either worked or it didn't. If it didn't work then tracking down the problem was easy.....
Now...... well, I just barely have any hair left.
I have spent my entire savings account to build this technological glory only to have it poop in my face.
(Before any comments are made, I have had just as many problems with AMD systems in the past as I have had with Intel systems.)
It is at the point where I am about to ship both the mobo and CPU back to the respective resellers and say "I want another please!"
I have had some good suggestions but any further thoughts before I rake out more on shipping and wait another 2-3 weeks to get this thing going?
I have got mid-terms and term-papers coming up and I refuse to use the computer at the library--- that 386 piece of junk.
E-mail
please read on....
