"Pretty" I-9 build plan
Kartajan
1. Use case: Custom Handbrake encodes, general use, light gaming, "Shiny lights"
2. Budget: $1500
3. Country: US
5. Brand preference: Not really, but looking to have "single pane of glass" on the build controls
7. Overclocking: Nothing too crazy, but since I am looking at overclockable parts- might have to push it a little bit 🙂
8. Resolution: 3840x1080
9. WHEN: Release week for 9th Gen Intel CPU's
10. Need to purchase any software? No.
I am planning to do a "pretty" build based on the Phanteks Evolv Shift X. the research that I have done suggests that the parts I have selected should fit, and that I should be able to hook it all into the RGB control built in to the motherboard for a single point of presence.
Any constructive input?
Intel Core i7-9700K
GeIL SUPER LUCE RGB SYNC 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000)
ASUS ROG Strix Z370-I Gaming LGA 1151 (300 Series) Intel Z370
CORSAIR SF Series SF600 600W 80 PLUS GOLD
Thermaltake Floe AIO Riing RGB 240 TT Premium Edition
Thermaltake CL-O015-PL00BL-A TT Sync Controller TT Premium Edition
Thermaltake CL-O014-PL00SW-A Pacific Lumi Plus LED Strip
$1250
Re- Using:
Samsung 960 EVO M.2 512GB
EVGA 1070 FTW2
KB/ Mouse/ Monitor
Win 10 Pro Retail
Well, it might be pretty and all, but it might not boot unless the Z370 already has BIOS updates that support the new 9700K. Maybe get a Z390 motherboard so you don't have to worry about that (unless you already have a Coffee Lake CPU where you can update the BIOS)
