steppinthrax
Not sure where this falls under, but this is more/less a mechanical question.
I have a 2350 psi pressure washer. It's worked well for a few years. I was looking at getting a new pump for it (online). I've been reading that most of the pumps only last around 5 years or so then they pretty much break. The pump housings are nice (brass bodies and aluminum). Yet the rebuild kits cost as much as the pumps themselves. So you buy a new pump online.
All the pumps seem to be made by a company called Annovi Reverberi. My thinking is the high pump failure rates may be attributed to the average consumer leaving the unit in a shed to freeze and break the seals inside. My unit has been losing pressure a bit. I pulled the pump apart last night and found some seals are more/less o-rings. Then there are these square seals that are for the pistons (3 pistons). The kit is pretty much 70 bucks!!! You're better off replacing the whole pump. I see 3000 psi replacement pumps made by Annovi Reverberi for 70 bucks.
Anyone have any experience in this?
