grrl
I removed the loud 60x60 high speed Delta fan from my Taisol HS and replaced it with an 80x80 Sunon fan. According to the specs, the Delta puts out 30 cfm and the Sunon 40, yet my CPU temp has risen 3 degrees with this mod.
Can anyone provide an educated guess as to how much of a drop in cfms I should expect when reducing the output of an 80x80 fan into a 60x60 hole? I took an old 80x80x25 fan, removed the guts and fared the inside down to 60mm with clear silicon caulk, so there are at least no right angles or hard edges to create excess resistance.
