An intel i3 4170 with an H97 board (for the outputs and ports) and 8GB RAM would be over three times as fast and have most of that built into the board itself. It seems the system has given up. It isn't exactly new.
I figure I need a few PCI slots. The HDTV card uses one, and it has a daughterboard. The daughterboard doesn't need a PCI slot but there has to be room for it next to the HDTV card, which it's bolted to. I have been in the habit of very occasionally using the fax functionality of that midtower. I guess my laptops have a modem built in, I've never tried using that. I should, for the occasional faxing I do, usually a send. Right now, there's a PCI fax modem in that midtower. I have a PCI firewire card that I haven't used in several years, but I want to be able to use it to grab video from an old video camera I have. I know, legacy crap. Also, my PCI soundcard, assuming it hasn't been fried, I like its breakout box.
I'm not super picky. In a mobo I'd like
Stable, won't crap out on me and fry my components (this has happened to me)
Several PCI slots
Support 2 digital monitors
Support faxing somehow (maybe not necessary if I can do that through my laptops)
Firewire either native or using a PCI firewire card, or I'd maybe have to get another firewire card
I don't game, so I don't need a very powerful system, and my current HDTV card has onboard processing freeing up the CPU for other things. I have never experienced slow computing while recording HDTV with that box in spite of its lack of power.
Support modern internal large capacity HDs.
I suppose USB 3.0 too.
I'm really out of the loop on modern systems. I've had to rely on external HDs in recent years because of the crappy SATA controller in that system. I have suffered 4 or 5 failures of said external HDs! My most important data is kept on a NAS with mirrored dual HDs, so loss of the data on the midtower isn't crucial, but it would be nice if it isn't lost.
