Zenmervolt
Elite member
- Oct 22, 2000
- 24,514
- 36
- 91
See my post above.Originally posted by: MisterMe
So if this kid is trying to save his car to the utmost extent, which way would you tell him to avoid the most wear and tear over the lifespan of a clutch/engine?Originally posted by: Zenmervolt
No, it does not. It uses more gas to coast. I went over that in my last post. All modern electronic fuel injection systems detect engine braking and turn off the injectors down to a specified RPM cutoff (typically 100-200 RPM above idle) at which point idle-level fuel-flow is restored. This means that exactly zero fuel is used during engine braking (until the threshold RPM is reached, at which point only idle levels of fuel are consumed), whereas coasting down uses an idle-level of fuel during the entire slowdown period as opposed to just at the end.Originally posted by: MisterMe
What I saying is in efforts to "save your car" you might avoid engine breaking an coast to stops. Doing this avoids the rpm spikes and save you gas.
This doesn't change the fact that you're wrong about engine braking wasting fuel though.
ZV
