Preparation for installing 9800 Pro
UnatcoAgent
5,462
Hey guys, I just picked up a 9800 Pro today, the 128 DDR version. It was on sale, I couldn't resist.
Anyway I was hoping for any pointers when installing a new video card. Basically what the process should be for replacing the card I have in now with this 9800. I currently have a TNT2 PCI and a Sapphire 9100 (main adapter) for running dual displays, both will be taken out.
Issues I'm worried about:
The first thing in the manual it says to do is to make sure you have proper AGP drivers installed, do I have to worry about this since I had a Radeon 9100 AGP card in prior?
Will my Antec ColdBlue 350Watt be enough to run this thing without having to worry?
System is as follows:
Barton 2500+ running @ stock settings
ASUS a7n8x Deluxé
1 Gig 2700 DDR
350 Watt Antec Cold Blue PS
160 ATA Westedn Digital
80 SATA Maxtor
LG Burner
LG DVD
Sapphire Radeon 9100 DDR + TNT2 PCI being removed.
Any tips are appreciated with this process guys, I realize it's very minor but I don't want to screw anything up.
Thanks.
OMGoddess
Banned
Jun 25, 2004
714
You're fine. Just make sure before you pull out the the others, go to device manager and disable them, then, unistall any drivers. Turn off put in your computer pull them out and put in the 9800pro. I think you know what to do from there.
UnatcoAgent
5,462
Roger that, so I should disable each of those display adapters individually, and then remove the drivers for them, powerdown/remove - put 9800 in and install latest Catalysts, correct?
OMGoddess
Banned
Jun 25, 2004
714
Yes. Be sure you at least have the drivers of the 9100 handy in case something goes wrong. Congrats on a new card.
UnatcoAgent
5,462
Is there a way to make sure all the previous Catalysts are off the machine? I seem to remember there being a utility that would make sure everything was wiped out, or does this really matter that much, as long as they are uninstalled?
OMGoddess
Banned
Jun 25, 2004
714
Doesn't really matter, if you uninstall it the normal way, most of it if all is gone. There won't be anything left for the OS to run because all the required commands are missing. It's just useless code. Eventually disk cleanup will get around to it.
UnatcoAgent
5,462
Amazing, thank you for all of your help.
I can't WAIT to get this thing in!
WobbleWobble
4,867
DriverCleaner
I never found it necessary, but for some people it has caused problems.
deadken
3,199
I would say that your power specs are fine for the power requirements you will now have. OMGoddess, was on the money in his suggestions, and you are right in your reply. Insolence is also correct that Windows should be able to detect the new card, and locate the driver files that you were using with the last ATI card you had. From there, just visit ATI.com and see if there are any new driver versions available.
BTW: What price did you pay, and where did you get it? You are killing me with the suspense!
deadken
3,199
Damn, this thread moved fast from the time I started my reply to the time I hit the 'Reply to Topic' button!
OMGoddess
Banned
Jun 25, 2004
714
I wouldn't mind knowing either.
mauiblue
652
I know there is freeware called "Drivercleaner" that suppose to remove all remnants of the Catalyst drivers. But when I installed the updated Cat drivers (4.10) I just used the Windows uninstall utility and then installed the updated drivers. I didn't have any problems after that.
BTW, I recently flashed my 9800 Pro 256mb/256bit card to the 9800XT BIOS. Now I have a little better performance in my core and memory speed and the Overdrive tab on the Catalyst Control Center is activated. I don't know if you can flash the your version (128mb) to the 9800XT BIOS though.
Good luck and happy gaming:D
OMGoddess
Banned
Jun 25, 2004
714
Did that for a friend, I was actually suprised that there was a noticable difference.
UnatcoAgent
5,462
Yah I think I'll do this in a year or so when it's time to upgrade again, but for now this card should be fine for all my gaming needs. The card was 279$ in CANADIAN funds, so 100 something for the American users, not sure what the exchange would be.
OMGoddess
Banned
Jun 25, 2004
714
In a year or so a 256/256 9800 will be worthless, in a year you can pick up a 6800ultra for the price that you paid for your current one.
Oh and you can't flash your 128/256 9800pro to an XT.
UnatcoAgent
5,462
Ok, I'm not huge into overclocking anyway. Thanks again OMG!
dguy6789
8,558
Take a deep breath once you get it. Now do yoga or pilates for the next 6 months to prepare you for the experience. Once you have done this, install it and use it.
mauiblue
652
OC or not, the card you got is a great piece of hardware especially at the price you got it at. It definately will keep you busy until the next great sale that comes along.
BTW, remember alway to reload your weapons before going around a corner or a Imp or Maggot (Doom3) will get you:evil:
