witeken
- Dec 25, 2013
- 3,899
- 193
- 106
The biggest factor in IGP performance is undoubtedly with the move from DDR3 to DDR4. Also, I believe Crystalwell will be making a more widespread appearance.http://www.cpu-world.com/news_2014/2014101501_More_details_on_Skylake_GT1_GT2_and_GT3_graphics.html
GT1 12 EUs
GT2 24 EUs
GT3 48 EUs
GT4 72 EUs
So there is no EU count change from GT1-GT3, they just added a third slice for GT4 variants. GT1-GT3 performance differences must come from architectural GPU improvements.
There was a presentation saying there would be a GT with 96EUs, quite a shame they don't double the EU count again. Which is easily possible with 14nm.http://www.cpu-world.com/news_2014/2014101501_More_details_on_Skylake_GT1_GT2_and_GT3_graphics.html
GT1 12 EUs
GT2 24 EUs
GT3 48 EUs
GT4 72 EUs
Although I do wonder what Gen9 will bring. I was hoping for more aggressive changes with Gen8, but it seems to be limited to basically re-balancing things. Which is fine, since the performance improvement form that will be fairly significant, but I think Intel still has a lot of catching up to do.
Well, that's basically what I was saying. What I was hoping for was a big architectural update, but that's not what we got. Still, the work that they did do should make Gen8 far more appealing, but I still feel like they'll be about a generation behind.Have you watched/read Gen8 information, it seems quite a major update to me, although there aren't fundamental changes to the architecture.
In particular it's funny to see them talk about AVX 3.2, while the official name has been known for more than a year and it's AVX-512.
Wouldn't that be Gen8? https://intel.activeevents.com/sf14/connect/sessionDetail.ww?SESSION_ID=1312
Unlikely, since Intel and Brian Krzanich stated multiple times that Skylak would ramp and launch in the second half of the year.
Arcodring to vr-zone the IGP part runs at twice the clockspeed of previous![]()
When the two were sending samples of the processor clock is 2.3GHz (Turbo Boost can to 2.9GHz) and 2.2GHz (Turbo Boost can to 2.4GHz), which 2.3GHz processor with GT2 Graphics, while the 2.2GHz version does not match any Intel HD Graphics.
I thought the IDF presentation was quite clear.It's unclear what he exactly means, it could be that he mainly referred to mobile and not to the entry server Skylake or desktop. The Roadmap indicated Q2, I think there is a delay into Q3 because Broadwell-K switched from Q2 into Q3 as well. In that case Vr-zone's informations are a bit outdated, it would explain their Q2 claim.
That does not pass my sniff test.
What is Intel up to?
http://wccftech.com/intel-14nm-skylakes-engineering-samples-spotted/
http://www.kitguru.net/components/c...r-with-disappointing-frequencies-to-partners/
I'm going to take a while stab and guess maybe Intel is trying to out HSA AMD and allocated a huge chunk of silicon to the GPU in an attempt to wipe out low to mid tier video cards for Nvidia and AMD.
What are the chances that Intel has radically designed the core and widened it substantially, a la Core 2, trading clockspeed for IPC?
The relatively low frequencies of the Skylake-S samples is a disturbing news since in many cases low clock-rate means low performance. It is unclear whether Intel will manage to boost frequencies of the Skylake-S chips by the time they hit the market.
[...]if this is true then Intel is well on its way to becoming a monopolistic tyrant.
Intel shipping at low clock speeds is not unusual for an early ES but you would think the TDP would reflect that. It would not surprise me if they are dealing with heat density problems, but not that bad.
BTW, couldn't it be possible that those are laptop chips? Intel said at IDF that the developer laptops would be shipping in Q1, IIRC.
