Pre-purchase review: SFF Shuttle build - FINISHED!
Kaido
Feb 14, 2004
50,742
6,769
Update:
Click here for pic (pencil on top for size reference)
Finished the build, everything is peachy. You need to do a BIOS update right away to fix a fan problem, but other than that everything is great. Well, that and the blue power LED is horrendously bright. Also, I wish I had gone with a quieter hard drive; I got the MaxLine for performance but it's sure noisy. A Seagate Barracuda or Samsung SpinPoint would have been a much better choice. Also my SATA DVD burner is fairly noisy; I should have read more reviews and found a quieter one. Overall the noise is on-par with my laptop - fairly quiet. Not silent though. Aside from the hard drive, it makes about as much noise as a new Dell tower.
It fits on my desk perfectly; I'm very pleased with the size. I really like having my DVD drive and memory card reader within reaching distance from my keyboard. Since I have a NAS setup and I'm not using this machine for gaming, I was able to get away with not having extra expansion options. Internally it can take a single PCI card and a single PCI-Express card. However, it cannot take a dual-bay PCI-Express card like an 8800GTX since the PCI-Express slot is on the left. So your gaming options are limited that way. I'm using a fanless card anyway (256mb Radeon X550, just for the DVI). Also, the reviews I read on Newegg said that it has proprietary 5-pin internal USB ports which meant that I would have to buy a Shuttle-brand card reader. I did this and dropped the Floppy/Card Reader only to discover that the case comes with a 4-pin adapter cable. Luckily I have a USB Floppy card reader (which I use mainly for flashing BIOS's) so it wasn't a big deal, but keep in mind that you can use any standard internal USB drive you want, despite what the reviews say - you don't have to purchase the adapter separately since it comes with the case.
Hmm, what else. I got an SATA DVD burner in addition to the SATA hard drive. Shuttle includes one SATA cable and one IDE cable, both pre-installed, so make sure you have a spare (long) SATA cable if you want to use a second SATA drive. It's actually pretty quick little machine - no IDE devices and no legacy devices. SATA hard drive, SATA DVD burner, and 3.5" USB card reader drive. All in all, the perfect little box for me. The $600 pricetag got me a quiet, compact computer, a dual-core processor, 2 gigs of ram, a DVD burner and card reader, and a 500gb hard drive (plus plenty of USB ports). Very pleased overall and would recommend it to anybody!
Original post:
I need a new desktop, mainly for Adobe CS under Windows XP Pro. Prices include shipping. Going for a semi-budget build. Just wanted a quick review to make sure I got everything right:
Shuttle XPC: $190
http://www.newegg.com/Product/Product.aspx?Item=N82E16856101020
1.9ghz X2: $59
http://www.newegg.com/product/Product.asp?item=N82E16819103036
2gb Gskill 800: $125
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231065
Maxline 500gb: $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144016
DVD burner: $39
http://www.newegg.com/Product/Product.asp?item=N82E16827136114
Floppy/Card reader: $25
http://www.newegg.com/Product/Product.aspx?Item=N82E16821104104
5-port PCI USB card: $15
http://www.newegg.com/Product/Product.aspx?Item=N82E16815104216
256mb Radeon X550 video card: $45
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102565
Total comes to $628 shipped.
eggrolls
268
well, i took a quick look at that shuttle, and it doesn't seem to include a heatpipe cooler for your CPU. and your CPU doesn't come with one either. also, you may want to get a SATA DVD burner as well, just for the thinner cables. i dunno whether memory timings matter for adobe cs, but there are cheaper ddr2 800 out there.
Kaido
Feb 14, 2004
50,742
6,769
What makes you say that it doesn't include a heatpipe cooler? That would be the worst idea ever :Q
edit:
one of the reviewers mentions one, plus the same model at eWiz says it has one. if not, I'll just return it and get the eWiz model:
http://www.ewiz.com/detail.php?name=MB-SK22GV2
Kaido
Feb 14, 2004
50,742
6,769
Originally posted by: Tick
I'm thinking you may be skimping a little too much on the X2. How about the 4200?
Nearly double the price. I'm running a 2ghz Core 2 Duo mobile right now, so a 1.9ghz X2 should be that much of a step down.
Kaido
Feb 14, 2004
50,742
6,769
Originally posted by: IsLNdbOi
Get a NEC / Optiarc AD7170 SATA or IDE whichever you prefer.
I wanted the LightScribe feature; Lite-on was the one with the best reviews. Just curious, why the AD7170?
Aluvus
2,913
You should have taken a longer look; it's visible in 3 of the 10 pictures that Newegg has.
wwswimming
Banned
Jan 21, 2006
3,695
Kaido
Feb 14, 2004
50,742
6,769
Originally posted by: wwswimming
looks like you don't like Stealth drive covers. me neither.
it will be a heck of a lot of system in a small space.
the Seagate 320 GB SATA is getting awesome reviews
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148140
$80
Yeah I'm pretty excited, I've never had a Shuttle before. My only other SFF computer was a Mac Mini about a year ago. I got a fully-decked-out Shuttle for the same price as the base Mac Mini model, that's pretty cool! As far as Stealth drives, I don't really care. I saw the price tag of $189 compared to $300+ on some of the other Shuttle models and decided to go for it. I just want something small to sit on my desk; I'm replacing a laptop on an iCurve stand. The onboard CPU fan is supposed to be pretty quiet, so I matched it up with a nice fanless video card and a quiet Maxline drive. I got a good deal on the Maxline because it's both quiet and about equal in performance with the Raptor 10k-rpm drives, plus I get 500 gigs of storage onboard. Yippie! I've also really wanted an integrated card reader, less stuff on my desk you know? I will return with pics when I do the build.
Yeah, I usually use that exact model Seagate when I build PCs for people. It's a great drive.
Eos
3,463
17
Nice.
I'd like to dump my AMD Socket 754 and full ATX tower for something like this.
Synomenon
10,547
Looks good. These little Shuttle boxes are great. My last four or five PCs have all been Shuttles. My current rig is a SD39P2.
