A friend of mine got a hold of a 17" flat screen, and has decided to get a new desktop to replace his laptop. He doesn't want to learn how to build a desktop himself, so I'm looking for recommendations for pre-built desktops under $1200. I think his requirements are something like this:
2.5 GHz+ CPU (AMD or Intel, he doesn't need top of the line)
512 MB or 1024MB RAM
120 GB HD or larger
DVD-ROM
CD-RW
128 MB Graphics card
In general, I'm trying to steer him toward buying a desktop with really good quality parts. I think it will be a good investment that way, instead of buying the equivalent eMachines system. Can anyone recommend a manufacturer (large or small) that builds the best pre-built PCs? And with the specs above as guidelines, what setup would you get for under $1200?
120 GB HD or larger
DVD-ROM
CD-RW
