PPro 200Mhz AND motherboard; $42.00
DanC
5,553
Don't SELL those!~ we need them for the 72 processor cluster!
DanC
5,553
BS! - make them DONATE them to Compucheap.
The least they can do!
ss59
Banned
pft for only $60 you can have a single cyrix 333 node with mobo and 32mb ram. 573kkey/s.
Netopia
4
As far as I can tell, the BP6 w/ dual Celerons at 500+ is still about the best bang for the buck. About $300 and you only need one stick of RAM and one power supply. Assuming that dual C500's should be able to go to 562 X 2 fairly easily, you can expect about 3.3Mk/s. I had a Dual 600 ('til I sold it) that was cranking out 3.4Mk/s... it's still cracking, but under a friend's name (on our team!).
I think the next big bang for the RC5 buck will be the Duron. If one can get one overclocked to the 900-1Ghz range, you'll get around 3.05-3.4 for around $200.
The next best thing might be if you could get the converter to work for the BP6 and go with dual 700's at 930. It would run about $600 and get about 5.2Mk/s. With the and coming Duron though, this wouldn't be a very cost effective setup.
What I'm hoping for is a low cost (ala BP6) dual Duron board. MAN...can you imagine getting a setup for around $300 or less that will pump out between 6 and 7 Mk/s! I'm drooling!
Joe
MooCow
237
hmm....Ppros seem to over clock pretty easy to 233, mine is happily crunching away at about 652kkey/s :)heck I could even play UT if I wasn't using this high quality S3 trio64 :| But we'll not go into how it does on starcraft :( Over all they are great chips still. I've got a 1MB pro, and it'll crunch away as a UT server with 16 bots pretty much with no lag over a LAN anyway. :)
Russ
<< What I'm hoping for is a low cost (ala BP6) dual Duron board. MAN...can you imagine getting a setup for around $300 or less that will pump out between 6 and 7 Mk/s! I'm drooling! >>
Yep, watch how fast I'd be replacing nodes on my rack!:)
Russ, NCNE
OS
15,581
that's my next upgrade when that comes out. The dual duron board that is.
