VirtualLarry
Anyone know?
Would two GTX460 1GB cards be better than four GTS450 cards? The GTX460 cards have 336 SPs, the GTS450 have 192 SPs. So 2x336 = 672, and 4x192 = 768.
What would the power-consumption difference be between the 4xGTS450 and 2xGTX460? It would require the same number of PCI-E 6-pin connecters, either 4x1 or 2x2.
How does GTS450 power consumption compare to 9600GSO 96SP power consumption?
I am currently running four 9600GSOs and an AMD 45W dual-core CPU off of an EarthWatts 650W (Delta). Runs fine as far as I can tell.
Space-wise, though, I wouldn't be able to fit four GTS450s, as I don't know of any that are single-slot. So I guess I would end up with three GTS450s. Would 3xGTS450 be faster than 4x9600GSO 96SP in PPD? I get around 4000 PPD per card on GPU2 F@H client.
http://www.techpowerup.com/reviews/Axle/GeForce_GTS_450_OC/1.html
Edit: Woohoo! Sparkle is making a single-slot GTS450. So I could shove four of them into my F@H quad-GPU rig after all. 🙂
http://www.techpowerup.com/133638/S...ingle-Slot-GeForce-GTS-450-Graphics-Card.html
http://hardforum.com/showthread.php?t=1558226
